Home > Help Needed / General Tech Chat > once again more questions
jufferb
Member #: 775
stourport-on-severn, worcestershire
hi,
im rebuilding my engine and wondered if i would need a center main strap and could somebody please explain what they are used for. i want to be running about 140 ish bhp.
my second question is what is the difference between a diaphram and a piston dump valve or a grp A.
cheers peeps
If in Doubt, go flat out !!!
A centre main strap bolts on top of the centre main bearing housing to help make it more rigid. It is a good idea really on any performance build engine, moreso as it is a cheap modification to perform.
SumpNut
Member #: 28
Do the centre main strap - they are dirt cheap to buy and the machining of the centre cap is very strait forward. The machine shop will certainly not charge much for it.
On a 3 bearing crank any extra support is more than welcome!
minispares strap & extra long bolts around 8 quid
when having it machined have it decked to the minimum with beingh flat
this should end up aroun 42 to 43 mm from the btm of the cap to the machined face on top!
the bolts supplied with this kit are just right!
minispares north ask for richard *wink*
Edited by BENROSS on 21st Dec, 2005.
Richie
Member #: 628
juffer as stated i would get it done, i have done on all of my performance engines,.....that and arp rod bolts....the reason it is done is under load (or high revs) the crank flex`s and you end up blowing big end shells or if you are unlucky like me you send an end cap through your gearbox / block / radiator / aldon dizzy / get the picture :) cheap mod that can save you a bomb
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
