Home > Help Needed / General Tech Chat > flywheel
jufferb
Member #: 775
stourport-on-severn, worcestershire
just a quicky, how much does a standard 1275 cast flywheel weigh.
If in Doubt, go flat out !!!
Which type, Lockheed type {older} or the A+ Verto type ? they are both different weights.
Phil. *smiley*
Richie
Member #: 628
if you are considering using verto i would re consider.........
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
the vertro isnt up to the job!
if you are even concidering high power levels
jufferb
Member #: 775
Why isn't the verto flywheel up to the job. i have a verto clutch (short arm) so im guessing that i have a verto flywheel. i hope to be running about 130 -140 bhp. i saw a flywheel on ebay that was lighjtened and i was just wondering how much does a standard flywheel weigh.
It is not the verto flywheel, but the clutch itself that is not up to the job, put simply, it will not take the torque produced by the turbo motors.
Benross has tried a supposedly uprated verto clutch on his car and has problems with it slipping in higher gears.
Nick
Member #: 154
Midlands
yup, my turbo verto clutch only lasted one day at avon park and that was only running around 110 bhp.
minimark
Member #: 19
newcastle
think about 22lbs ??
jufferb, i may have jumped the gun a touch!
as i did not want you to fall into the same trap as me & others
by going down this route
the pre vertro can be lightend a lot more than the vertro flywheel
jufferb
Member #: 775
guys, what im trying to do is lighten the flywheel and put a grey diaphram and ap race and rally clutch in. but in this thread you are saying that a verto clutch is no good for massive power and torque. so what do i need to change to make my clutch work without slipping and only lasting one day.im trying to get about 130bhp.
The 'grey diaphram' is only usable on pre-vero flyweels. eg:
http://www.raromachine.com/mini/enginestri...20001-small.jpg
whereas you have a 'verto' flywheel. eg:
http://www.auto2.ru/epc/rover/mc0507.cgm.gif
The 'grey' is the triangular shaped thing in the top pictue. It doesn't feature on verto units.
