Home > General Chat > wireless routers help.
santa brought one of my girls a wireless router,
it says plug it into the dsl filter with one lead on the fone line , then use the other from the router back into my computer, but the lead they supply to go into my computer dosn't fit , i am assuming they mean put it into a usb port , but its a different fitting , is it because mines old and the new lead is up to date,also it dosn't say what to do with my existing modem.i am using wanadoo broadband
am i making sence??.
bloddy computers ,i hate em!!!!!.
carl
Richspec
Member #: 300
Cumbria
just guessing but the lead sounds like a network connection?? bit like the phone connection but slightly bigger?
One for the IT guys i think!
Edited by Richspec on 25th Dec, 2005.
Here for the craic..
Supercharged Arden powered
Kean
Member #: 341
aka T2clubby
South Staffs
Is it a wireless router and modem in one, or just a router
sounds like (i think its called) an ethernet connection
i think you need a network card in the pc, there could be one there already. Its an area that looks like the normal phone line connection but is a slightly different fit.
dont worry about the modem, that is no longer needed
or you could get a usb wireless widget that just plugs in and use the pc wirelessly
........I think....
andeh
Member #: 97
Near Daventry, midlands
i think some pics or model numbers/makes are needed along with what equipment you are replacing is needed to give accurate usefull help.
Mirage
Member #: 119
it will be ethernet like Nic sais.
it' s a Belkin ADSL modem with wireless router,
so i assume i dump the wanadoo modem and plug this thing in ,so i need a different lead from router to computer do i?? or do i mget some king of adaptor??.
it does say earthernet on the box,
carll
Doodmeister
Member #: 149
Alberta, Canada
Your going to need an Ethernet card in your PC if you don't already have one.
Centre Connector.
im running the same set up
you dont need the wanadoo thing anymore
do you have an ethernet lead?
look for an ethernet connection on the back of your computer, the symbol is a line with 2 squares below it and one on top
not the best pic but look at this:
this shows the connections on my laptop
on the right is the ethernet connection, middle is modem phone line, end is 2x usb ports
you either want to run an ethernet lead from the router to your pc
-or if you havent got one of those fit a network card, get a wireless usb thing that will allow you to connect to the router wirelessly
oh doodmiester used posted whilsts i was tapping away
thanks men , doodmieater is showing the socket that i dod not have on the back of my pc, it about 5 years old now , how do i gat one of these fitted or is there a way around this, the socket you are showing is like the lead i got to connect my wireless thing to my npc ,this must be the earthnet lead then,?
one more thing too fella's. i just bought my wife a laptop notepad thingy, i was wondering how to get internet access for it but one of my girls has turned it on and it says there is a wireless connection available ,or words to that effect ,whats going on??. so we tried it and it works.
carl
you can either get something like this and run it wirelessly (but will requiring openoing up the computer, but its quite easy)
http://www.novatech.co.uk/novatech/specpage.html?NOV-54GPCI
or just plug this into your usb port http://www.novatech.co.uk/novatech/specpage.html?NOV-54USB
or use an ethernet cable with this:
http://www.novatech.co.uk/novatech/specpage.html?NOV-320XR1
the wireless connection available is yours, click on it and connect to it, job done
Edited by Nic on 26th Dec, 2005.
ok so i'l sort out the adapter thing, cheerrs ,
but how is the the wireless connection mine, i havn't connected my wireless thing yet ,
carl
oh, it could be a neighbours....
Doodmeister
Member #: 149
Alberta, Canada
Umm free broadband from the neighbours can't beat it *wink*
jamesfawcett
Member #: 218
Bingley, West Yorkshire
mines free from neighbors too at my mums it was the local school haha
