Home > General Chat > a-series turbo with looong primaries in the manifold
evolotion
Member #: 83
Glasgow, Scotland
case you havnt seen it : -
Denis O'Brien.
and a std bulkhead!!
edit: duh, no its not
Edited by Nic on 30th Dec, 2005.
antman
Member #: 358
Snetterton, Norfolk
Interesting interpretation, i would assume to give some kind of tuned primary lengths? Although i would guess that with a turbo primary lengths are not a whole lot important!?
I don't see the point. Tuned primaries are used to give the reflection shock wave "extractor" effect at a certain engine speed in a NA engine. But with a turbo engine, you have boost pressure to extract more power from the engine, so tuned lengths becomes pretty ineffectual.
If the effect of the long manifold tract lengths was to move the turbo away from the bulkhead, meaning no bulkhead box, I could see the point. But other than that I don't get why the chap has done it like this, what does it add over and above the standard exhaust manifold?
equal length manifold primaries are good on a proper 4 pot, but i dont see the idea on a siamese port engine...
It's to do with pulses - ands the length of them in a turbo... Picture - if you had (for example) 12" in the outer 'a', and 2" in the inner 'b' and 12" in outer 'c'.
Order of 'action' from firing order 134213421342.... is therefore abcbabca....
If you have such a short length of 'b' then it's clear that you'll have a 'gap' in flow inpinging on the turbine wheel when 'B' has finished. Also - there will also be a point that there is a 'double' volume when 'a' or 'C' have finished, as 'b' will already be at the turbine...
How much of a difference? I don't know. But i do know that i'm going to go equal length on my runners - because it is bound to be better. 10% better or 0.00000010% better? I don't know!
Remember ; The middle branch is separated by 360 crank degrees, so you can treat it as 'two' separate pipes to all intents...
Edited by turbodave16v on 30th Dec, 2005.
giallofly
Member #: 164
The Stig..
Newport Pagnell
Anyway fcuk about lenghs of pipes!
Had a look at his site and it is quite a project!...a realy thought out flip front, the weight of it would keep Fastcarls sleepless for a week but it is a "proper bo" job.
Antone notice is "oil injection/olie injectie", seem to put out a smoke screen at the push of a button.
Good effort!
Edited by giallofly on 30th Dec, 2005.
intresting!
Ah - Cheers for clearing that up Dave - I didnt realize that was the firing order on a mini. I'm showing my a-series newbie side now.
benjamin
Member #: 621
nsw austalia
would the advantage be lost as the flow is reduced because of the sharp corner into the turbo?
1152cc turboed mini clubman, most powerful 1.1L a-series?
http://boostmini.justboard.net/
Kean
Member #: 341
aka T2clubby
South Staffs
Read through it all, that guy is a genius.... very over engineered.. which is good
has any one noticed the back plate where you cahnge the followers on the block? *wink**wink*
Edited by Miniwilliams on 31st Dec, 2005.
Doodmeister
Member #: 149
Alberta, Canada
I think you'll find it's for mock up only and the real deal is coming later.
Carl
Member #: 95
liverpool-on-sea
have you seen the pics of his home made roll cage, he was bending the pipes in his front room lol.
i wish i was that handy and had the patience to do stuff like that.
03-01-2005 - To keep noise down for my neighbors I placed the workbench on rubbers. On the floor I used the Mini rubber balls, as used in the suspension, and on the wall I used Mini engine mounts.
http://www.xs4all.nl/%7Ethimo/dagboek/03-01-2005.html
Love it!
Edited by turbodave16v on 31st Dec, 2005.
turbo hogster
Member #: 178
stowmaket suffolk
ill give that manifold about 3 months before it cracks been better of in stainless as its a bit more resistant to cracking.
Richie
Member #: 628
clearly alot of thought time and expense has been poured into this one, the custom exhaust alone must have taken ages, a true genius, i hope it turns out well and gives him all he expects from it, but i reckon it will, and some .....
Richie
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
I see what your saying now!*wink*
