| Home > Help Needed / General Tech Chat > Cam bearing removal | |||||||
31st Dec, 2005 at 05:27:16pm
Hi guys, im back "Turbo's make torque, and torque makes fun"
31st Dec, 2005 at 05:29:40pm
Hammer and drift.........
31st Dec, 2005 at 07:28:20pm
It's much easier letting the guy that fits the new ones take the old ones out. He won't score the races either.. On 13th Jul, 2012 Ben H said:
339 Posts Member #: 399 Senior Member Austria |
13th Apr, 2006 at 12:45:24pm
OK. Cam bearing removal with hammer and drift.
13th Apr, 2006 at 01:08:36pm
I made up a set of pullers on the lathe at work, as per the instructions on the APT website, works a treat!!
13th Apr, 2006 at 01:44:25pm
righto, to get mine out, i made my own puller using a long threaded bar and a snug socket
13th Apr, 2006 at 03:53:28pm
With the cam bearing tool I made, the first set i put in went in pretty easy after I removed the scoring in the block where some one had removed bearing previouly, I pulled them in, and slid in the cam, which was tight, I traced this to a nick on the centre journel of the cam, removed this with a stone and the cam then fitted snug but not tight. On 28th Aug, 2011 Kean said:
13th Apr, 2006 at 10:06:47pm
I intend to have turned up a drift that allows each bearing to either be driffted out or in whilest locating in all three bearings journals/ bores thereby eliminating any miss alignment. Cam should fit first time with no damage to any of the bearings. Unlike the apauling job the guy did on the ones in my 1400 block and i paid him to do it.
14th Apr, 2006 at 09:04:23am
they need reaming out to size once fitted thats why its just as easy to get a good engine machine shop to do it.
14th Apr, 2006 at 11:08:50am
apparently if you do it right, with a proper tool, theres no need to ream them... "Turbo's make torque, and torque makes fun"
14th Apr, 2006 at 09:23:58pm
well joey i havnt herd of one yet unless the cam you are using has worn journals.
14th Apr, 2006 at 09:25:43pm
I have to say I have never needed to ream cam bearings, after all they are similar material to crank shell bearings and you wouldn't dream of reaming those!
14th Apr, 2006 at 11:39:45pm
Good point Tom, never though about it like that.
15th Apr, 2006 at 05:00:41am
I've also never had a problem where the whole thing needed reaming. I've had a 'high spot' before though - which generally reveals itself as a tight cam (twist the cam a few times and the high spot is obvious).
Edited by turbodave16v on 15th Apr, 2006. On 17th Nov, 2014 Tom Fenton said:
