| Home > Show Us Yours! > Update | |||||||
![]() 323 Posts Member #: 41 Senior Member |
21st Feb, 2004 at 06:53:07pm
got the front all on and welded up. just gotta fix the bonnet down with some pins and wait until the fibregalss one comes. had to cut the arch slight coz i couldnt turn the wheel all the wheel full lock, got new arches coming too A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
Site Admin 6297 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
21st Feb, 2004 at 07:55:34pm
blimey, you're working fast! |
21st Feb, 2004 at 09:17:51pm
cant really afford for the car to be off the road mate lol the welding part takes no time at all, just a couple of seam welds and spot welds, its getting the crappy non-genuine panels to fit right and look half decent that takes up most of the time A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
22nd Feb, 2004 at 04:59:32pm
Yeah, still, it looks dead good. I wish I had the knowledge/space/money to do that sort of thing |
22nd Feb, 2004 at 05:20:43pm
thanx A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
![]() 439 Posts Member #: 176 Pre-op Transvestite Felixstowe, Suffolk |
22nd Feb, 2004 at 11:42:32pm
i like the use of complimetary colours (red and green) in that engine bay :) NO LONGER A <3 lover of BOLT-ON plastic <3 .... (and DOUBLE proud of it) |
23rd Feb, 2004 at 11:56:33am
did you get my pm? Yes mate :) We'll be adding some bits to the site soonish..
23rd Feb, 2004 at 05:35:07pm
ideal, cheers! A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
