Home > General Chat > Do you still need to drill the thermostat...
...if you have the outlet from your cyl head tapped straight into your top-hose??? (no heater)
I'm going for a 'no'.
Peeps agree?
Edited by turbodave16v on 3rd Jan, 2006.
andeh
Member #: 97
Near Daventry, midlands
i agree, under starting before the stat opens the water will route through the heater output and into the top hose making a route for water to circulate. Presuming of course that you dont have a bypass ala metro/latemini
Edited by andeh on 3rd Jan, 2006.
b12
Member #: 247
Kent/Surrey Borders
TD I have drilled a hole in every thermostat I have every fittted to Minis; escorts ; anglias ; triumphs ; etc
I am probably just VERY Paranoid
But then again I did used to have a triumph stag :)
TurboLessTosser
Ha ha ha !
I'm glad you used the word 'did' in the sentence describing your ownership of a Slag.
Fancy going to all the effort of designing a great engine like that - and then putting a POS cooling system on it!
iam with the thought of the holes on this one
I'd say no as well... The is now a giant hole between both holes of the thermostat.
gregor
Member #: 98
Slovenia
i was driving with drilled holes in thermostat last season and my engine was running to cold all the time. even in the hot summer time i had less than 60C on the high way driving. during the "normal" town driving was max. 70C
i will try without holes this season.
Edited by gregor on 4th Jan, 2006.
no holes for me = faster warm up time:) I haven't had a hole for a while, (enough or my personal life though!) and like hoggy says most people have the heater on the head open any way, which would help movment up that way.
Edited by Miniwilliams on 4th Jan, 2006.
T3Tone
Member #: 252
Sunny suffolk
Agreed with the no holes option
-MINI CLUBMAN 1380 TURBO-
turbo hogster
Member #: 178
stowmaket suffolk
i third that
the no holes option is ok well and good but....... i have mine piped up exactley like dave is proposing to
with out the holes on a 74 deg stat, faster warm up fine! theres a but with my engine ...
it always had a tendency for the temps to go bordering up to the 90 to 100 c mark giving it some bongo!
with 6 / 6mm holes slower warm up but the temp is now FULLY controlled with the stat
i suspect that it may well be one of those blocks ?
thats my engine*wink*
Edited by BENROSS on 4th Jan, 2006.
Yes ben that's a weird one, i was going to say you need another or a bigger rad, but that all must be ok as you can with the holes keep things under control. very strange mate.
Maybe the stats no good?
may be its new but....
i have found dozens of new stats over the years U/S
its an option are the holes
I've noticed that the temp can get too low with the drilled holes too, but iI still like to stick a small (about 1mm) hole to help get rid of any trapped air under the stat.
