Home > Help Needed / General Tech Chat > what power?
jufferb
Member #: 775
stourport-on-severn, worcestershire
how much power does a standartd cam produce. say if i was using 10 psi.
If in Doubt, go flat out !!!
Depends on what head, valves, cr, pistons you are using.
And even then who knows, it depends on individual engine build.
What a pointless question anyway, the avonbar ph 2 cam produces the goods big time and costs pennies, why piss about with the standard cam?
jufferb
Member #: 775
i was just wondering because i didnt want to buy the phase 2 cam and have to change the cam bearings like your suppose too. i was going to leave the standard cam in and not mess with the cam bearings. if the bearings are good do i have to change them?
Edited by jufferb on 3rd Jan, 2006.
MG Metro cam is good and very cheap.
If you are going to skimp on things as trivial and cheap as cam bearings then I would think twice about building a turbo mini. Everything and I mean EVERYTHING needs to be in tip top condition to give it any chance of lasting more than about 5 minutes. Especially the gearbox.
jufferb
Member #: 775
cheers tom thats the kick up the ass i needed
Not wanting to be harsh but that is the reality I am afraid.
jufferb
Member #: 775
can i change the bearings at home easily or is it best to get a profesional involved.
Its not that hard to do, but if you are unsure an engine machine shop will do them for you for not a lot of money. If you are going to have the block bored get them done at the same time, or take the block along when you get a cylinder head skimmed etc.
I'd say ALWAYS let a professional with the correct tools change the cam bearings. They are so ridiculously soft and easy to ruin.
Also, if you change the cam, there is no rule that you have to change bearings. I've reused bearings through three cams at least with no ill effects.
