Home > Help Needed / General Tech Chat > front camber
jimmy
Member #: 829
essex
im using 165/60/12 tyres if you put negative camber arms on what would you use 1.5 or 2.0 camber
1293 Turbo mini
antman
Member #: 358
Snetterton, Norfolk
It all depends on wot u use the car for? The best ones are prob the adjustable ones as the tolerances on the subframes that i have worked with haven't been quite equal side to side.
I used to work on a Mighty Mini race car and that was fine with the 1.5 degree arms but it all depends on your driving style!!
jimmy
Member #: 829
essex
toe down and left braking sounds good
1293 Turbo mini
jimmy
Member #: 829
essex
so adjustable tie rods are a good idea what would you set the caster at if the camber was 1.5 would you say 2.0
1293 Turbo mini
With 10" wheels normally upto 1.5 degrees
12" & 13" wheels upt .5 degrees normally
This is only a general rule, try experimenting
Paul
mines on 13s
camber 1.25 deg
caster 5.5 deg
its great ! but try experimenting, theres so many settings
i think iam not too far out !
this caster setting almost eliminates the torque steer from the sheer shove of the turbo
jimmy
Member #: 829
essex
thanks for the ball park it all helps the car is fitted with hi los so i will be having fun ?
1293 Turbo mini
