Home > Help Needed / General Tech Chat > 5th injecter
jufferb
Member #: 775
stourport-on-severn, worcestershire
my mate has a 5th injecter fitted to his escort rs turbo in the plenem to help with the leaning out at high RPM. has anybody tried one?
If in Doubt, go flat out !!!
On a carburated turbocharged mini?
jimmy
Member #: 829
essex
its not going to work because the fuel pump is low pressure so if you used a std injector high pressure when the injector opens the fuel line pressure drops so the fuel reg is not going work properly plus were you going to put the pipe work and injector
1293 Turbo mini
arent fifth injectors an old school bodge for fuel injection cars?
wa thinking about it for mine but i had no wires to fire it open:(
Star Mag
Member #: 375
Leicestershire
I have a mate who uses a injector with a pressure switch too give extra fuel above 18 PSI on a R5 turbo, which works too great effect!!!
jimmy
Member #: 829
essex
you can on r5 its because the pump output is high on flow
1293 Turbo mini
It's a bodge.
Star Mag
Member #: 375
Leicestershire
Yeah it may be a bodge but it works and ya get good power for not alot of money, The injector runs it own pump so fuel supply is not a problem.
jimmy
Member #: 829
essex
good one
1293 Turbo mini
