| Home > Technical Chat > Turbo carb ? | |||||||
![]() 399 Posts Member #: 793 Senior Member Milton Keynes |
8th Jan, 2006 at 08:26:25pm
Is it possible to mod or buy a 45 dcoe or a 40 dcoe to run on a turbo engine? I understand they lean out as the boost rises
![]() 508 Posts Member #: 487 Post Whore westbury, wiltshire |
8th Jan, 2006 at 08:27:24pm
yes the weber or dellorto has to be turbo specific "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
8th Jan, 2006 at 08:43:26pm
On 08/01/2006 20:27:24 nogin said:
yes the weber or dellorto has to be turbo specific Would someone like Southern Carbs be the caps to speak to? http://i28.photobucket.com/albums/c248/spe...er1/mini007.jpg
1300 Posts Member #: 829 Post Whore essex |
8th Jan, 2006 at 09:15:51pm
the carb will need to be sealed on the throttle shaft etc because its n/a when you put it on a turbo system the pressure forces fuel out of the shaft and fuel bowl etc but it can modified good luck 1293 Turbo mini
8th Jan, 2006 at 09:35:27pm
SOrry to ask the same thing again...
AlexF |
8th Jan, 2006 at 09:43:11pm
fuck know`s to do air flow possibly ?????????????? 1293 Turbo mini
8th Jan, 2006 at 09:53:03pm
On 08/01/2006 21:35:27 AlexF2003 said:
SOrry to ask the same thing again... but why!!! SU works well till EFi is sorted! Alex ^^^^^^^^^^^^^^^^^^^^^^^^^^^ What he said !!!! Do a searh for Dellorto using the search command and you'll find plenty of posts, many from Jukka (wise folks listen when this man speaks) which should be read and understood before jumping... Edited by turbodave16v on 8th Jan, 2006. On 17th Nov, 2014 Tom Fenton said:
8th Jan, 2006 at 09:55:24pm
On 08/01/2006 20:43:26 Gavin Wakely said:
Would someone like Southern Carbs be the chaps to speak to? What about? Getting your arse waxed? I guarantee they'll know naff-all about this - especially when using it on an A-series. Jukka is your man - and he'll say to stick with the SU.
9th Jan, 2006 at 05:56:06am
On 09/01/2006 01:10:02 mini1071s said:
The SU can cope with 220 bhp proven. 1 3/4 SU has been proven to cope with 300+bananas in the MG Montestro's over the years... Edited by turbodave16v on 9th Jan, 2006. On 17th Nov, 2014 Tom Fenton said:
