Page: |
Home > 998cc > Help please... | |||||||
![]() 321 Posts Member #: 557 Senior Member Ireland |
9th Jan, 2006 at 12:39:05pm
My budget is running low and my main priority at the moment is getting the car sprayed. Now I'm still a couple of parts short of being ready to fit the turbo but I will be removing the engine prior to getting the car painted in order to spray the engine bay and to clean up the engine. What I was wondering was - I have both the inlet and exhaust manifolds ready for the turbo conversion, as the engine is going to be out anyway and I need to replace the whole exhaust (accident with a ramp at the mechanics :p ), can I replace the standard manifolds and fit my metro turbo inlet and exhaust ones while still keeping the rest of the engine engine as is for now or will this bugger everything up? |
9th Jan, 2006 at 12:40:42pm
btw, I am by no means giving up on the turbo conversion! I have all the main components except for a fuel tank, the ECU and a load of pipes and hoses. However the single most expensive thing left to do on my list is to get the car painted so I'm going to get that over and done before I spendd any more money. |
9th Jan, 2006 at 12:42:47pm
I don't understand what you are asking. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
9th Jan, 2006 at 01:01:23pm
No, me neither.
9th Jan, 2006 at 03:02:16pm
sorry, I just re read that and it makes more sense in my head :p
9th Jan, 2006 at 03:11:37pm
me to :) its starting to cost a fortune at this stage :p |
9th Jan, 2006 at 03:33:00pm
Cheers Peter.......
9th Jan, 2006 at 06:00:31pm
On 09/01/2006 12:40:42 snowfruit said:
.... I have all the main components except for a fuel tank, the ECU and a ....... Just a quick one - You dont need the ecu mate - Do a search on the website to find out why :) |
10th Jan, 2006 at 09:44:35am
thanks for that Tom.
10th Jan, 2006 at 10:18:13am
KISS
63 Posts Member #: 834 Advanced Member Falmouth, Cornwall |
10th Jan, 2006 at 11:10:05am
If you are using megajolt, the motor should start up regardless of settings as the EDIS controller defaults to 10 degrees advance in limp home mode without the ECU attatched. Something would have to be horribly wrong for it not to work, as long as it has power, verified by a multimeter or just a bulb and crocodile clip, it will start the engine. I started mine up without the jolt ecu attatched, no map sensor etc.
Peter
Page: |
