Home > Help Needed / General Tech Chat > Engine Building first time suggested reading etc
Stig
Member #: 694
Shropshire
Couldn't find a lot in the search apart from references to corky bells book on force induction. So here goes.
I am looking at giving my old metro turbo motor a health check before putting it back in the mini etc. Apart from the Hayes manual, is there any other books for recommended reading before i start to take then engine apart?
Please bear in mind that i am not an engineer / mechanic etc so this type of thing is virgin territory *tongue* for me.
Edited by Stig on 9th Jan, 2006.
mikemph
Member #: 449
Oxford
David Vizard tuning book for a series engines, thats a haynes book btw
this is a good read
http://www.amazon.co.uk/exec/obidos/ASIN/1...0416893-1205459
Could lend you my copy as you're local.
Wil
Edited by wil_h on 9th Jan, 2006.
The David Vizard bible is great for WHAT to do to your engine, but there is not a lot on HOW to do it.
The book Wil recommends looks good, I have often considered buying that one myself.
Yep I have both the hamil books and they have useful stuff like bearing and piston and ring clearances that arn't mentioned in the vizard book.
I was also going to say that book that Will reccomended. Vizard was carefull not to go into that as 'building' is another subject (as witnessed by this book - LOL!)
Stig
Member #: 694
Shropshire
Thanks for the surggestions chaps.
Will i will buy my own copy i think as it could take some time to build the engine.
Another pointer I suppose, is to look in the Haynes manual for clearances relating to the engine. If there is a clearance quoted, generally you need to check it.
As a start;
Ring gaps in bore
Crank Endfloat
Cam Endfloat
Bearing clearances maybe?(Plastigauge)
Piston crown to deck height
i am quite pleased this thread came up ive bougt myself the book will pointed out
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Its a good read :)
Alex
AlexF
