| Home > General Chat > Advantages of a roll cage | |||||||
11th Jan, 2006 at 09:19:15pm
I came across this comment about roll cages on minifinity
11th Jan, 2006 at 09:32:00pm
I'm assuming that your answer is the bottom parragraph?
Edited by turbodave16v on 11th Jan, 2006. On 17th Nov, 2014 Tom Fenton said:
11th Jan, 2006 at 09:37:01pm
Well I never answered the comment on minifinity.
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
11th Jan, 2006 at 09:38:07pm
as per dave, what i have found is that any cage will rigid up the car. however if the cage is welded to the shell with tabs ie down the "A" pillars, "B" pillars, floor etc. the shell becomes much stronger. this i can corroborate through seing cars rolled over. the ones without the cage welded on the points mentioned needed new shells after the crash. the ones with were ok, a few dints in the top pannel of course, but the integrity of the shell was intact !
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
11th Jan, 2006 at 09:54:14pm
is it tony falls who set up safety devices?
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
11th Jan, 2006 at 11:28:59pm
Got to admit i can see it not adding a lot at all. |
12th Jan, 2006 at 06:29:03am
Interesting.
12th Jan, 2006 at 07:12:48pm
In my Vauxhall (hehe) I had a full welded in rollcage, with a crisscross section in the rear and all the door bars etc. It was welded to the rear arches, and front floorpans and somewhere along the middle of the floor area too.
12th Jan, 2006 at 07:39:01pm
ive got a standrd 6point saftey devices roll cage with door bars in me clubman, me clubbys a solid shell good sills, good inner sills, good floor etc when its level on the ground the doors shut ok but when the fronts up on axel stands the doors dont close the same. they sort of catch a little on the latches if you know what i mean. dont know if thats relefant or not its just something ive noticed.
12th Jan, 2006 at 09:06:04pm
strange..carl that sounds like the bottom of ya "A" pillars are rotten the bit behind the apex that the door bolts onto..........one thing you do need to consider regarding rigidity is if you have cut holes everywhere for lightness ie the cross member on the floor, or if you have removed the rear seats and havent replaced it with a brace bar. my metro was totally stiff, no flex at all, my rear seats were replaced with an aluminium sheet to cover my beam axel, the rest of the car was basically a roll cage welded intot the shell, the only part of the origional floorpan was the front footwells everything else was aluminium sheet. so once again i can confirm if the cage is fitted properly welded onto the points, and the structure of the shell is intact it will increase the stiffness...in feebs case and carl i would bet my hat i would find structural failure on their shells causing the shells to "Sagg" around the cage or the cages were not welded in the correct spots (not trying to cause offence here btw lads)
12th Jan, 2006 at 09:10:34pm
I think that a bolt in 6pt cage properly fitted (and emphasis on properly) does without a shadow of a doubt increase the stiffness of a car. However, by tying it into the A and B pillars, I think this would increase the benefit even more.
12th Jan, 2006 at 09:39:58pm
my first turbo i cant find any rot in the areas conserned its just one of them things i fink only moves a tiny weeny bit probably a nats nudger. no longer a series, but still 1.3 turbo.
12th Jan, 2006 at 10:16:48pm
aye nee botha lol :) just when u said, i had a shell in the past where the doors did exactly what you said, at first i thought the hinges were jiggered......wish they had been
13th Jan, 2006 at 01:10:41am
On 12/01/2006 19:12:48 feebleuk said:
In my Vauxhall (hehe) I had a full welded in rollcage, with a crisscross section in the rear and all the door bars etc. It was welded to the rear arches, and front floorpans and somewhere along the middle of the floor area too. going round ANY corner, even light corners, if you put your fingers in between one of the roof rollcage bars and the shell, there was flexing. It wasnt that much, but on faster corners i got dan to see how much the gap between the shell and rollcage changed and it could be up to a centimeter. The suspension was set to very very stiff though and there wasnt much suspension travel and it was seam welded everywhere so there was alot of stress on the shell. This is a fantastic answer off Feebs IMO - especially if you consider this is a modern car with (I assume) a bonded screen. The old 'finger' test is clearly a goodun. In my very limited experience of mini rollcages - they are usually touching (certainly after you hammer the door seals back in place) the top of the a-pillars, so it might not be so easy to judge however... On 17th Nov, 2014 Tom Fenton said:
![]() 928 Posts Member #: 326 Post Whore bradford, west yorks |
13th Jan, 2006 at 04:30:56am
going round ANY corner, even light corners, if you put your fingers in between one of the roof rollcage bars and the shell, there was flexing. It wasnt that much, but on faster corners i got dan to see how much the gap between the shell and rollcage changed and it could be up to a centimeter. it did move a lot i cant think how much the shell would twist on its own with no cage but its obviusly a lot harder to measer with no roll bar to feel the distance lol. Dan |
13th Jan, 2006 at 06:28:08am
this reminds me a bit of an old tale that submariners used to tie string across the submarine, and when they went deep the pressure would crush the hull and the string would sag...
13th Jan, 2006 at 06:49:55am
On 13/01/2006 04:30:56 pot_dan said:
it did move a lot i cant think how much the shell would twist on its own with no cage but its obviusly a lot harder to measer with no roll bar to feel the distance lol. Dan That's a good point dan. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
13th Jan, 2006 at 07:53:09am
my first hill climb mini was 1971 clubman, a bit of a shed ,but road legal, i fit only a rear hoop for safety, sometimes i would take it out on a sunday marning and thrasg it aroung "Tingley Roundabout " which is J28 M62. the one you get off on for the white rose centre in leeds ,
13th Jan, 2006 at 08:19:16am
On 12/01/2006 19:39:01 Carl said:
im planning on getting another set of door bars and fitting one across the front botom dash area. and fitting the other across the legs that go one the rear arches, any1 ever done this? ![]() I've done this at the front, attaching the steering column in it.. The column now sits FIRM without the floppyness you get in the original mounting points and a lowering bracket. I'll get a picture up.... On 13th Jul, 2012 Ben H said:
13th Jan, 2006 at 08:22:14am
I agree that the standard steering column can be a bit floppy, however I have always stayed away from messing with the mounting points, simply because in the event of a big accident, I don't want the column to be so rigid and solidly mounted that it turns into something that could seriously injure the driver.
13th Jan, 2006 at 08:32:06am
I agree, But I'm hoping the 6 point will help me there... :) It's a racecar with an LSD. YOu really need the column to be mounted like this as the original ones WILL break. On 13th Jul, 2012 Ben H said:
