Home > Technical Chat > turbo smoke
if a turbo only smokes when hot i assume thats the seals, whats involved in fixing and can this be done by me or does it have to all be rebalanced?
Carl
Member #: 95
liverpool-on-sea
there should be loads on here about this wolfie. do a search*tongue*
you can do it yourself but its a bit risky so i think its one of them chances really. id say if your running standardish boost order a kit of iain mark every thing up compressor and turbin posistions etc and go for it, this is just my opinion and what i did i cant be responsible if it breaks and knackers your engine lol*smiley*
Dan's doing the kits now *smiley* from the same place/price etc etc just i dont have the time to give the high class of service *smiley*
turbo hogster
Member #: 178
stowmaket suffolk
best way is to check the exhaust pipe for exh tubine seal gone or inlet from the blower for the inlet.
it could just be down to valve guides or piston rings.
valve guides is easy just jack the car up at the fron and see if it disapears.,
