Home > 998cc > 998 spec and output
andeh
Member #: 97
Near Daventry, midlands
Thought i might start this as im still at the planning stages of my 998 turbo build and i want to know how far to take it.
What have people on here got (spec) and what are they getting from them in terms of bannas and torque (name escapes me?)
Edited by andeh on 13th Jan, 2006.
PM me youe email and I'll send you a spec sheet of the old engine.
You'll have to wail 'til sunday though as it's on my work computer.
Wil
garethlloyd
Member #: 616
Birmingham
Wil, I would be most greatfull if you could send that to me too!
gareth.lloyd2@tesco.net
MAGA7INE
Member #: 834
Falmouth, Cornwall
Evo 1. Stock low milage 998 with uncut 12G295 cooper 998 head, (28cc chambers), T3, no intercooler, megajolt ignition and benross magic elbow, maniflow 2" downpipe, lambda sensor bung + sensor, 10 psi actuator. Turbo verto clutch set up. High volume oil pump.
Evo 2. As above with Audi TDi intercooler and 14 psi.
Evo 3. As above plus ported 295 head and MG metro cam.
These will all be dynoed and the results published. So a stock 998 basically with just the parts changed that have to be to fit the turbo.
Second 998 build is underway.
Se7en spec 998 crank. Wedged, bladed.
Hillman imp pistons 71mm bore.
Custom cam grind.
Light rods, good rod bolts.
Ported 295.
T3.
Aiming for 150+ bhp.
There is a third small bore as well, 850 turbo.
MG metro cam.
998 block bored +60 thou with minispares mega pistons (998 cooper).
Se7en spec 850 crank. (936cc).
Lightened rods.
Garret GT15 turbo.
295 ported head. 8:1 CR.
Megasquirt EFI port injection.
Who knows what power I will get out of the 850? The RR will tell :)
Peter
Editor
MAGA7INE
Seven Magazine
The brand new quality Classic Mini Tech and Journal
Issue 1 out late 2027.
Staggy
Member #: 947
New Zealand
I have had my 998 turbo dynoed and i am getting 155hp at 14psi of boost. This is with the water/meth injection running. I am currently running 8psi with the water/meth kicking in at 7psi
Caution !!!! Slippery when boosting
cripes with these 998's popping so much out and being 277cc down on the 1275 it makes me wonder if the extra 105cc's of the 1380 will make much difference
Staggy
Member #: 947
New Zealand
I am not using a T2 or T3 turbo. I am using an IHI RHB5 VI13 turbo of a 1600 Mazda 323. Also using the intercooler from this engine.
I will post the dyno sheet when I manage to find it in my mess.
Staggy
Member #: 947
New Zealand
I am using twin delortes 45. connected straight to the compressor side of the turbo. Therefore the turbo is compressing both fuel and air. Pics are up in the photo section under "Staggy's 996 Turbo"
Staggy
Member #: 947
New Zealand
opps i mean 998
