| Home > Technical Chat > deck height | |||||||
![]() 368 Posts Member #: 806 Senior Member Cirencester, Gloucestershire |
15th Jan, 2006 at 04:57:50pm
does anyone know the deck height of 18cc +0.020" je pistons?
15th Jan, 2006 at 05:12:51pm
What are you assuming? I am fairly sure they are std compression height, so therefore will be approx 40 thou down the bores when used in an un-molested block?
15th Jan, 2006 at 05:18:46pm
cheers mate. ive had 6 thou skimmed off the block, so 34thou then.
15th Jan, 2006 at 06:59:45pm
Those are only approx values, of course tolerances do vary, so you would need to check, but with a 6 thou skim I would be very suprised if you have any problems.
