Home > Help Needed / General Tech Chat > venting a fuelcell
Dangerous
Member #: 417
Do I need a valve on it,and do you loop the pipe or go out through the boot floor ??
Clueless
Mirage
Member #: 119
For road or track ?
Id run the vent up and loop it back down and out the floor. For track use you'd need a valve in there.
in my err, moped days i used to run the carb overflow pipe and loop it round twice, this would stop the fuel pouring out when encouraging wheelies from the monsterous 49cc's
Dangerous
Member #: 417
It's for road in the spare wheel well of my metty turbo. I took the std tank off to do some welding and can't be bothered to put it back on again,after all the hassle getting it off.
Also is it ok to have the battery (in a battery box) next to the tank.
jimmy
Member #: 829
essex
you can use a valve but some times the fuel lays on top of the valve and it dont vent right so just loop the pipe and go out the boot floor that is ok
1293 Turbo mini
