| Home > Technical Chat > crossdrilling crank | |||||||
119 Posts Member #: 772 Advanced Member new york |
19th Jan, 2006 at 06:06:44pm
is it worth doing on a 1380 with 12psi?
19th Jan, 2006 at 07:30:16pm
Definately a high-revving engine thing...
19th Jan, 2006 at 09:34:23pm
that's what i was thinking thanks |
20th Jan, 2006 at 05:46:46pm
My first Swiftune crank was just wedged, it was fine for upto 9000rpm, it lasted over 2 years before I spun centre main.
I seriously doubt it! |
24th Oct, 2006 at 01:34:57pm
is it any point in crossdrilling both the mains and big ends? or are just the mains necessary? |
24th Oct, 2006 at 02:47:20pm
The thing is, that all cranks have the hole in the big end on the wrong side. It should be on the inside, towards the main centerline, not the outside. However, this contributes to large costs.
24th Oct, 2006 at 11:43:09pm
If you look at an A+ crank closely, you will see that the oil holes in the main journals are not at the same angle. so oil is fed from more than one bearing at different degree angle of rotation. There is always oil fed to the bearings, despite what ive read else where, saying that because of the plain bottom bearing there is no oil feed to the big ends through half the rotation.
Edited by Sprocket on 24th Oct, 2006. On 26th Oct, 2004 TurboDave16v said:
25th Oct, 2006 at 09:17:15am
What do you mean by not the same angle? There is only one hole in the journal. That's the problem.
30th Sep, 2009 at 03:08:02pm
Sorry, old thread revival
