Home > Help Needed / General Tech Chat > Turbo engine can work without ECU?
supermini
Member #: 187
I'm a recent member and i have some difficulties
I have a 1275MG turbo engine from 1985 to fit in my mini, but i dont have de ECU.
Does the engine work wihout it? how?
I'm from Portugal and here I cant find one ECU.
Thank's
Carlos
Edited by supermini on 27th Feb, 2004.
Jim
Member #: 125
Yes it will work but you'll only be able to boost to around 4 psi IIR.
Once the engine's past it's peak torque range the ECU allows the boost to increase to around 7psi, meaning more bhp at the top of the rev range without the gearbox-killing torque that 7psi would create at 3000 revs.
I'm sure others on here can advise you about alternatives for the ECU.
Jim
I don't know one engine with one! LOL
Basically the ecu and its bits are a fancy bleed valve which controls the boost solenoid. Replace the boost solenoid with a bleed valve and remove the ecu. Block up where the ecu was. Job done *happy*
Carl
Member #: 95
liverpool-on-sea
make sure you fit a good boost guage so you know how much boost you are adjusting to
