Home > General Chat > champion RN12YCC
Dangerous
Member #: 417
Any idea why the haynes book recomends these for a 87-89,I put a set of RN9YCC's in as doing a search on here most use 8's and 9's.
turbo dave will like this bit !!
These were to replace a set of ngk 6's that only went 30 miles before dying
jimmy
Member #: 829
essex
what you putting the plugs in
1293 Turbo mini
a metro turbo engine i would of presumed?????
Dangerous
Member #: 417
A 1988 metro turbo
It might be that that Champion use a different 'scale' of heat range than (cough spit) NGK ?
You'd never want to use a '9' in any road-going (cold starting) daily driver motor - least of all a production unit...
Skinns46
Member #: 165
Cambridge
If it's standard try the NGK B7ECS. A bit more boost would probably be the B8ECS.
Roland
http://photobucket.com/albums/y139/Skinns46/
Dangerous
Member #: 417
In the spark plug holes*tongue*
Dangerous
Member #: 417
yes but why champion 12's on a 86-88 and 9's on a pre 86 is it because it's unleaded
jimmy
Member #: 829
essex
in the spark plug hole
what like the NGK6 for 30 mile ha ha ha ha ha ha ha ha
1293 Turbo mini
I've actually still got several NGK plugs lying around...
I use them for putting into heads when measuring the chamber volume! They seem to be very reliable in this particular application. Never had one fail yet ! LOL!
jimmy
Member #: 829
essex
looked in the autodata
RN12YC is for mini 1.0
metro turbo bosch WR7DC 0.6mm
champoin RN9YCC 0.8mm
NGK BPR6ES 0.9mm
beru 14R-6DU 0.8mm
if it helps
1293 Turbo mini
Dangerous
Member #: 417
Just been looking at an old link
Champion plugs higher number hotter
ngk plugs higher number colder
