| Home > Help Needed / General Tech Chat > megajolt and mini rev counters | |||||||
1050 Posts Member #: 764 Post Whore Staffordshire |
24th Jan, 2006 at 09:50:06am
Hi guys i'm hoping this will be a nice easy question for you.
24th Jan, 2006 at 09:59:17am
I use an output on the EDIS connected directly to the white/black signal wire to the revcounter.
1300 Posts Member #: 829 Post Whore essex |
24th Jan, 2006 at 06:44:06pm
you can do what wil_h done use the output from the EDIS
1293 Turbo mini
24th Jan, 2006 at 08:01:59pm
i havent figured mine out yet, i just have a shift light to rely on, which currently points into where the dashboard used to be!! |
28th Jun, 2006 at 11:52:39pm
I bought a 12v rev counter from ebay, i dont have a rev counter wire comign from my EDIS, ive tried the megajolt wire but that doesnt workwith it do i also have to make up that circuit with the diodes? Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
29th Jun, 2006 at 12:37:02am
you can drill the edis plug and get a signal from there |
29th Jun, 2006 at 12:37:38am
you need to drill out the EDIS plug and insert your Rev counter wire. the connection should be present in the EDIS unit but there wont be a hole in the plug for the wire to go through. Anton, kean and myself have all had to do it this way. Edited by Nick on 29th Jun, 2006. On 20th Oct, 2015 Tom Fenton said:
29th Jun, 2006 at 01:14:02am
great will do that in the morning thanks alot :)
29th Jun, 2006 at 08:17:16am
The other option (if you are really struggling) is to get the rev counter re-calibrated to 2 cylinders and run it of on side of the coil pack.
http://www.twin-turbo.co.uk
