| Home > Help Needed / General Tech Chat > crank help | |||||||
25th Jan, 2006 at 07:46:18pm
i have a crank here all standard with 12G1505 on it whats it from? will it fit an A+ block and if i paint it yellow and stick it on ebay will it fetch loads of money Crystal Sound Audio said:
25th Jan, 2006 at 07:55:57pm
Crankshaft - Standard Production Crank Identification
25th Jan, 2006 at 10:22:35pm
CAM6232 1275cc - Rolled-fillet radius on bearing journals, A+ with 1.75" dia. big ends
25th Jan, 2006 at 10:26:11pm
Keith Calver's minispares article said:
Below is a list of crankshaft identification data by forging or stamped numbers - yes, contrary to what many say/express, all cranks are forged. None are cast. They wouldn't last 2 minutes in an engine if they were cast - they'd be way too brittle. The differences are in the material used, finish machining detail and any heat treatments applied. It is by no means complete and utterly correct/infallible since Austin/Morris, British Leyland, Leyland cars, Austin Rover, rover, et al were seriously prone to not adhering to specifications and applications lists. But it is better than nothing at all! 22A62 850cc - Early type with oil feed for primary gear, 1.375" dia. tail 22A63 850cc - Early type with oil feed for primary gear, 1.375" dia. tail 22A298850cc - Early type thin-nose crank, 1.375" dia. tail 12A670 850cc - Later type with 1.5" dia. tail 12A298 997cc - Original Cooper crank 12A375 997cc - Cooper crank with oil feed hole for primary gear 12A595 998cc - Early EN16T spec 12A1451 998cc - Later, pre-A+ EN16T spec BHM1436 998cc - A+ spec, 1985 onwards (12A1451 forging) 12G82 1100cc - Standard across the board transverse A-series EN16T spec AEG330 970cc - EN40B forged, non-cross drilled AEG171 1071cc - EN40B forged, non-cross drilled AEG315 1275cc - Cooper S, EN40B forging, Nitrided, 1.625" dia. big ends, non-cross drilled AEG316 1275cc - Cooper S, EN40B forging, Nitrided, 1.625" dia. big ends, non-cross drilled AEG479 1275cc - Cooper S, EN40B forging, Nitrided, 1.625" dia. big ends, cross drilled AEG480 1275cc - Cooper S, EN40B forging, Nitrided, 1.625" dia. big ends, cross drilled AEG623 1275cc - Cooper S, EN16T forging, Tuftrided, 1.625" dia. big ends 12G1287 1275cc - Non-S, EN16T with 1.625" dia. big ends 12G1288 1275cc - Non-S, EN16T with 1.625" dia. big ends 12G1505 1275cc - Non-S, EN16T with 1.75" dia. big ends 12G1683 1275cc - 12G1505 forging, non-S, EN16T with 1.75" dia. big ends, Tuftrided CAM6232* 1275cc - Rolled-fillet radius on bearing journals, A+ with 1.75" dia. big ends *Note: This crankshaft was used in all 1275cc, A+, transverse engines including the MG Metro Turbo. There are various un-confirmed opinions on the subject of whether the material was any different, or whether it was heat treated differently. It would appear that early Turbos had just the standard spec, EN16T, non-heat treated type fitted. Later examples certainly appear to have been heat-treated, probably an up-to-date, emissions-friendly version of 'Tuftriding' (a recognised ICI registered process) - possibly a forerunner to Nitro-Carburising. These crankshafts have a distinctly charcoal-grey/black finish - mostly detectable on the webs, water pump/alternator pulley end and in the rolled fillet radii. The later being fairly 'deep' and very even. Article Date: Oct 27, 2003 thats the full article, cant link to it cos minispares site is shite! On 20th Oct, 2015 Tom Fenton said:
25th Jan, 2006 at 10:34:21pm
When that was first published in minimag, I contacted KC and asked why he'd left the 6581 out of the list...
25th Jan, 2006 at 10:35:38pm
Excellent info!
Edited by BENROSS on 25th Jan, 2006.
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
25th Jan, 2006 at 10:41:24pm
12g1505 were fitted to GT engines, these are the best for stroking using an S-sized big ends IIRC. Worth a bit of money for that very reason if they are on std size journals. I've seen the future and tbh its Pie
26th Jan, 2006 at 07:11:35am
They were fitted to anything 1275 A-series, NON S. On 13th Jul, 2012 Ben H said:
26th Jan, 2006 at 08:55:32am
so basically Wolfie,it's a door stop,
26th Jan, 2006 at 08:57:34am
or send it to me, i'm closer so it'll be cheaper On 20th Oct, 2015 Tom Fenton said:
