Home > General Chat > rear subframe
jimmy
Member #: 829
essex
my subframe is fucked it is like a patch work duvet
do i fit std subframe
or do i fit a beam
WHAT DO YOU THINK ?????????????
1293 Turbo mini
ehat are you using the car for? probably a subframe, ow a pole just fell on me
jimmy
Member #: 829
essex
I`m using the car on the road but looking to do some runs on the track
1293 Turbo mini
subframe, welded up if your feeling keen, adjustable camber/toe brackets, hi los and dampers, jobsagoodun!!
jimmy
Member #: 829
essex
you mean weld the new subframe be for i fit it
I`ve got hi los
and spaxs
1293 Turbo mini
yeah just seam weld it, dunno if its actually needed, but it could be wise
i have a beam and coil overs but i wouldnt of said its actually worth the effort for road and track, rear end protection is a consideration in a bump
