Home > Help Needed / General Tech Chat > Which engine?
superseven
Member #: 190
I've got all the needed turbo-stuff (carb, turbo, manifolds, ecu, fuel regulator, boost-modulator valve, just no distributor) to build a turbo-mini. As i still have to buy a Mini, which 1.3l engine is the best to use? It is hard to get a genuine Metro-turbo block, but with a lot of 1.3 metro's & mini's out there, which one should i consider? *smiley*
Greetingzzz, Rob
any post 86 metro / mini with a 1275!!!
Go for the best you can find...
