Home > Technical Chat > Hif
Turbo-Aseries
Member #: 610
Barbados W.I
i know this has been ask already, n yes i did a search(didnt find everythin i need)
But i would like to know all the things u need to do to get a normal hif carb to turbo spec.
thanks.
a link to a website etc would be very helpful.
Dangerous
Member #: 417
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=6298
Dangerous
Member #: 417
Tee number 7 into the pipe that goes from No 1 to the plenium
Change needle and spring to turbo ones
Turbo-Aseries
Member #: 610
Barbados W.I
that was fast..
thanks alot.
So the float chamber doesnt need pressurizing then??? through the float bowl vent tube....( i was told this)
Dangerous
Member #: 417
Yes the fuel pressure and the air pressure above the float must be higher than the boost pressure,which is due to the plenium outlet (senser pipe)being the carb side of the restricter
Turbo-Aseries
Member #: 610
Barbados W.I
On 27/01/2006 22:51:51 Turbo-Aseries said:
that was fast..
thanks alot.
answered that one for myself jus now*wink*
Turbo-Aseries
Member #: 610
Barbados W.I
thanks again....
so jus to clarify 'teeing' 1 n 7 will pressurize the float chamber??
You don't need to connect 7 to anything - just block it off. Same with 8.
6 is fuel inlet - as described.
So long as you use the plenum with the restrictor at the mouth of the carb, and a hole that lines up with the (horizontal) internal porting just below 3 and 7 then the carb will be pressure sensitive.
Also - to make a decent job of it though, pull the carb apart, and machine a groove to take an o-ring between the body and dashpot cover. The O-ring incidentally is the same as the one between the body and float bowl cover.
Also, reverse the outer lip seals on the throttle spindles and choke.
