Home > Help Needed / General Tech Chat > Non Verto clutch slip
Dizzy Dazzler
Member #: 878
I am currently using a bonded clutch plate nailed down with a grey diaphragm on a billet ultra light flywheel and backplate, the problem is im getting clutch slip in third and fourth with just 134Bhp at the wheels (is a turbo lump).... is this right??? Have checked clutch seal etc...... any advice guys!
Three driving straps on your flywheel no doubt?
Reduce to two, machine backplate lug height to 23.5mm, and it's as good as it can be. After that - it's a double grey or a sintered plate.
follow daves advice, I did it helped lots, but I still had to go for a double grey
Dizzy Dazzler
Member #: 878
Thanks guys will try that. With a double grey cover how long will the thrust washers last???
If you never press the clutch pedal, years and years...
If you sit with your foot on the pedal, seconds and seconds....
