| Home > Help Needed / General Tech Chat > drop gears | |||||||
![]() 508 Posts Member #: 487 Post Whore westbury, wiltshire |
1st Feb, 2006 at 03:07:14pm
hi just trying to detremine a problem i have, i know some of you have had drop gear problems and want to see if this is what is wrong with mine, i have that anoying little chatter going on at idle, so i put in the clutch and it goes, when i start to drive it sounds like i have a set of straight cut drops, or the closest i can think of the sound is a squeeking fan belt, done all the checks eg fan belt tight, so would you think it is the drop gears or maybe my release bearing i am thinking drops
"Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
1st Feb, 2006 at 03:15:55pm
It canot be the release bearing. If it was it would squeal when the clutch was depressed.
1st Feb, 2006 at 03:27:16pm
having a new gearbox so no need to worry just wondering if my diagnoss was right which i think it is
1st Feb, 2006 at 04:08:35pm
Got exactly the same problem on antons gearbox at the minute. we're pulling it out on saturday and stripping it down.
1st Feb, 2006 at 04:22:42pm
well it doesnt sound pretty but im sure it is this that is the problem "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
1st Feb, 2006 at 04:35:11pm
If the idler gear bearings are knackered then when driving, the torque will be causing the gear to thrust into a different position, this will give you the whine as the gear teeth contact in a different place. Could also be the first motion shaft nose bearing gone as well.
1st Feb, 2006 at 04:54:09pm
ye i will find out what it is when i strip it, just a bit weird as i drained the oil to see if i had any bits but nothing only the usual swarf on the magnet "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
2nd Feb, 2006 at 08:02:25am
That's because the idlers are situated in aluminium. I guess you'll fi nd a lot of aluminium debris when you open it... On 13th Jul, 2012 Ben H said:
