| Home > Help Needed / General Tech Chat > Head bolt torque? | |||||||
Site Admin 6297 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
4th Feb, 2006 at 09:59:54pm
Going to re-torque the head bolts tomorrow as I've pretty much run the Frog in now. What setting should I put my torque wrench on?
4th Feb, 2006 at 10:04:29pm
50 lbft says metro haynes....
AlexF |
1300 Posts Member #: 829 Post Whore essex |
4th Feb, 2006 at 11:06:28pm
autodata std 68NM 50LB
1293 Turbo mini
5th Feb, 2006 at 11:14:50am
I always set my torque wrench to 70NM. I assume mu wrench is not ammazingly accurate and I~'d rather be tight than slack.
5th Feb, 2006 at 11:17:32am
Cheers :) |
133 Posts Member #: 703 Advanced Member Plymouth, On the floating skip known as HMS Albion |
9th Feb, 2006 at 06:01:43pm
If you over tighten the head bolts won't that squash and distort the gasket? Whats going to break next!?
9th Feb, 2006 at 07:42:31pm
On 09/02/2006 18:01:43 slim_shadyuk said:
If you over tighten the head bolts won't that squash and distort the gasket? I think you would probably strip or break the studs before you damaged the head gasket. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
13th Feb, 2006 at 01:41:11am
if you overtorque the head you'll 'distort the fire-rings' which can lead to them burning out (particularly between bores) due to the fact that the are more exposed. I dont know how true that is, but i did notice that one of my gaskets had a funny profile on the fire ring and did burn out between 2 and 3. I've seen the future and tbh its Pie
