Home > Help Needed / General Tech Chat > Plastic caged bearings
oh poop
just finished off my gearbox, and i built it with a plastic caged mainshaft and first motion bearings
is this a bad bad bad idea? will they violently explode on me wrecking everything, or will they last a year of abuse?
thanks
SumpNut
Member #: 28
Whats wrong with plastic ?
The worst I have ever seen of a plastic cage was a few cracks?
I'd rather have broken plastic in my box than lumps of metal floating around...
turbo hogster
Member #: 178
stowmaket suffolk
here here, metal cages are stronger but when they go they make one hell of a mess
I've never seen a metal caged main bearing ???
FEW!!!!!!! that saves me needing to pull the beast apart again
turbo hogster
Member #: 178
stowmaket suffolk
ive seen a bronze gaged one before and it was well shagged so was the rest of the gearbox.
you can get welded or riveted cages if you do get a metal one then only use the riveted ones as there are alot stronger than the welded type.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
IIRC early ones had a metal cage...
Alex
AlexF
I've seen loads of metal caged ones!
Remember I generally loathe A+ stuff *wink*
