Home > Help Needed / General Tech Chat > Boost?
Metro Turbo
Member #: 437
Sunny Blackpool
Hi
Just had the engine re-installed. I have a boost gauge fitted,
how can i tell if the ECU is working?
Are there anyways of telling if the ECU is connected up by checking anything under the bonnet? eg, wires etc?
Cheers, tim
89' Metro Turbo
157 BHP , 170 lb ft @ 15psi .... So far....
Mikeanics Rolling Road
WINNER OF RETRO CARS SHOW BEST 80's MODIFIED CAR
well, it'll boost to around 4psi until something like 4500rpm, when it'll rise to 7psi...
If it stays constant - something ins wrong.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
pull the ECU out....
you dont need it *happy*
Alex
AlexF
Dangerous
Member #: 417
Just put a switch on the bleed solinoid,for 3 or 7 psi at the flick of a switch
minimark
Member #: 19
newcastle
might not be the best idea if its in a metro
minimark
Member #: 19
newcastle
that was meant for alex`s post
Metro Turbo
Member #: 437
Sunny Blackpool
I'm still running it in, and haven't pushed it past 4500rpm yet, so I'll have to check out what maximum boost is once I've got some miles on it.
Cheers for the info, Tim
89' Metro Turbo
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
why not mark?
Alex
AlexF
minimark
Member #: 19
newcastle
always thought the ecu controled more in the metro ??.. is it not linked to the neon`s aswell ?
jimmy
Member #: 829
essex
bin the ecu and run a bleed valve
1293 Turbo mini
