Home > Technical Chat > Wanted turbo but problems
duckpowder
Member #: 891
Hi
Im a noob first post yay, well basicly i liked the idea of a turbo on the mini so i did some research, i have a mini metro A+ 1310 motor 1989 and after talking to someone he said i need to
change my pistons to decompressed pistons, change my head to a decompressed head, change my gear box.
this is even bofore i get the turbo parts so is this correct, it seems so expensive but ooo well any help would be great on my situation and what to do
thankyou
Mini_Andy
Member #: 432
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=6
and welcome
duck power do a search on this forum for the questions you are seeking.
then if you get stuck! ask on the help section.
you will soon be Boosting by those Chavs!
duckpowder
Member #: 891
hi
Yeah i have read that lol quite helpful lol
But is there anything i can do about the piston situation??
and with the head do i need to have a decompressed head or a decompressed turbo head??
thankyou for your help
they are the same heads except the very early turbo 940 castings which had a thiner deck height if iam correct!
if you are using 214N stainless race valves in the exaust then things are fine
if the pistons will make the grade??
ask on the help section give the guys the spec of them including number etc
if they do? make the grade then de beak the head inorder to lower the CR ratio for you to run more boost
i can provide this service for you at a small charge if you wish?
PM me for details.
theres no problems only solutions!*wink*
Oh! & dont for get the intercooler
the intercooler is not the icing on the cake its MORE CAKE!*wink*
CORKY BELL
Edited by BENROSS on 10th Feb, 2006.
