| Home > Help Needed / General Tech Chat > diff spring thing. | |||||||
![]() 928 Posts Member #: 326 Post Whore bradford, west yorks |
10th Feb, 2006 at 01:17:13pm
when i removed my diff i remeeber seeing a spring with a little ball bearing in the end that wa release when i took the two side bits off the diff casing.. i ahve the spring but lost the bb, what can i do? i want to finish building it today and cant go much further without knowing what i can do!. will check moss catalogue if they sell it cos there just 2 secs away but other that that i dont know, what does it do anyway? it seems to touch the selector rod or something?
10th Feb, 2006 at 01:19:17pm
It is a detent ball that stops the selectors moving out of gear on their own. You do need it. There should also be a sleeve as well.
10th Feb, 2006 at 01:23:10pm
ok, thanks will look for moss catalogue.
10th Feb, 2006 at 03:06:17pm
like tom says you do need it
10th Feb, 2006 at 04:00:21pm
ring minispares... they stock them I believe!
AlexF |
10th Feb, 2006 at 04:51:25pm
hthanks for quick replies, moss dont have them but my old 1 litre had one:). then i found out the sleve and the bb seemed to stay in place after all, i dont know how i knew about it if it dident fall out, is there anotherone i have overlooked that might have fallen out and is as importnant?
10th Feb, 2006 at 06:25:47pm
There should be the metal sleeve, with 1 ball bearing and a spring. It is all compressed up together when you bolt the diff side cover on.
10th Feb, 2006 at 06:57:36pm
yeah i had that, i thought i remeber seeing a spring and a bb falling out, i found the srping and just asumed i had lost the sleve and ball bearing, but when i got a new sleve and bearing i noticed the sleve was already there, and i tried to push the spring and bb in but it wouldent conpress so i checked and 2 bbs fell out, lol
10th Feb, 2006 at 07:03:12pm
oh i also wanted to ask if the oil filter housing has a gasket? i dont remeber tearing one off when i took it off, but it was about a year ago and slepts many times since then.
10th Feb, 2006 at 07:05:47pm
Between oil filter housing and block??
10th Feb, 2006 at 07:08:27pm
ok cheers again, this wont be the end of silly questions as i get nearer the end, lol it will never end |
11th Feb, 2006 at 01:32:33am
if you cant find a gasket to fit then i always make my own out of an old school textbook cover On 20th Oct, 2015 Tom Fenton said:
612 Posts Member #: 414 Post Whore Dalbeattie Scotland |
11th Feb, 2006 at 08:13:27am
We didnt have books or joters when I was at school we used slate and chalk.What else can you use? |
11th Feb, 2006 at 09:47:24am
pmsl...how about an old cornflakes or porridge box On 20th Oct, 2015 Tom Fenton said:
11th Feb, 2006 at 11:45:46am
i used cornflakes boxes on all my carb to inlet t head gaskets on my old 1040 and did thousands of miles with no trouble at all:) i asume they will be fine in this case with it being oil and not petrol?
