Home > General Chat > Which is more mini?
which, in your opinion, is more a a mini:
1x mini running an a series engine, but coil overs, plastic flip front, quite lightened, looks messed around with19 Votes 19 Votes - 0%
1x mini, with a vauxhall engine, but suspension as issigonis inteneded, all steel, not so lightened, looks genuine8 Votes 8 Votes - 0%
Edited by Nic on 12th Feb, 2006.
actually i have no idea....
A series + mini 'look'
Turbo Tim
Member #: 177
Avon Park 2006 Class D Winner
Woburn Sands
A series and min look for mee too
16V project underway
It's not a Mini without an A-series ! *tongue*
jimmy
Member #: 829
essex
mini with A-series (turbo)
1293 Turbo mini
ben doodar
Member #: 595
stoke on trent
a series
As you never specified Which vauxhall engine, I've run with the vauxhall to be honest *blush*
IMO, once you take the 5-port head off an a-series, it's no longer an A-series aswell...
you see im thinking the vauxhall mini would be more mini as you get the mini enjoyment due to it having the mini suspension
the engine in question was a 1.6 nova engine, so it doesnt ruin the handling like an xe would, also it has all steel body, as a mini should
hmm we were having a drunken a series vs nova argument, then i completely confused myself buy making that point
(damn, ive been sigged, cheers phil)
Carl
Member #: 95
liverpool-on-sea
are you on about your matesmini clubman that was at combe if so that was very nice and very well engineered, looked better than a factory fit engine bay.
well, I built a 1.6SE mini for the GF before i left England using the Allspeed kit.
100hp; 100lb ft, 5psd box (with corsa TD FD - 5th is equivalent to a 2.7 in a mini box) and it all fitted in a round-nose.
Without a doubt - the nicest road-going mini i've ever driven; and more 'mini' than something running on a rear beam, coil overs, flip front, perspex'd, etc, etc, etc...
Well; that the opinion of someone who's ACTUALLY built and driven one at least... *wink*
Would you guess there is a vauxhall engine hiding under here?
Edited by turbodave16v on 12th Feb, 2006.
yep, thats the one carl
i would say its more of a mini experience driving it than what mine has evolved into
Carl
Member #: 95
liverpool-on-sea
TD have you got any pics of the engine bay, im not building one or planning on im just curious.
nic your mates was very very nice very and very well built. it even looked good facing me when he spun at combe( i was a bit scared that moment)
makes you wonder if its worth spending all this money on a series doesnt it when you could build sommething like the above that wont need rebuilding every year.
i know its not a mini if its not an a series but im changing my opinion on this a little. theres lots of manuacturers that use all different engines in one model isnt there. and what with the price of the a series engines geting dearer and dearer.*smiley*
pot_dan
Member #: 326
bradford, west yorks
i dnt think it matter what engine/suspension it has. if its a mini shell, its a mini lol, i would even call space frame chassis with a mini tub on a real mini*tongue*
jamesfawcett
Member #: 218
Bingley, West Yorkshire
If old people come up to your mini and say
"I used to have one of these..."
then its good enough to be called a mini :)
This was still work in progress - Engine was running at this point...
Note the loom is the original vauxhall loom. All that is different is that tha grommet through the bulkhead is slid 6" along the loom more towards the engine end. It feeds nicely through, and the ECU sits behind the dash where the glovebox is.
Servo is the standard rover one - suitably re-positioned. Header tank is mpi / metro. Screenwash reservoir is stock 1989> mini.
I've never seen an engine (apart from the a-series) that looks so 'right' in the roundnose engine room.
If you're interested, check out www.1.6mini.co.uk *wink*
Carl
Member #: 95
liverpool-on-sea
looks good that dave i seen one at wirral to llandudno run that had an extended front on that had the biggest overhang on the front and it looked horrrid.
