Home > Help Needed / General Tech Chat > Brake/Clutch master cylinder bulkhead plate
Mike
Member #: 107
Sunny Sussex
the plate thats on the bottom of the brake and master cylinders...
does anyone know if they come with the rubber gasket under them or if they are separate. Mine was all brittle and toasted so need a new one.
Edited by Mike on 12th Feb, 2006.
just binned one! oops!!
i'll see if i can dig it out.
just re-read that. you mean you need a metal plate? there is a normal gasket under it as far as i can remember.
Mike
Member #: 107
Sunny Sussex
i've got the plate, just needs a bit of a clean and paint, but the rubber gasket under it was stuffed. I presume its there to prevent water being trapped?
gasket is sold seperately.
You can cut one out of an old inner-tube or something pretty easilly - Or just use some mastic, or something simiar.
jimmy
Member #: 829
essex
I used mastic on my car no leaks done a year ago
1293 Turbo mini
Mike
Member #: 107
Sunny Sussex
cool, got some in the shed somewhere :)
I use inner tube as per Dave...
Strangely, I was doing exactly the same job as this when you started the thread, Mike.
I've managed to get hold of some neoprene (rubber mat). It's spot on for the job.
I've got plenty and can cut you off a piece and post it if you want. Neater than mastic and cheaper (FREE).
PM me your address if you want a bit.
Wil
Mike
Member #: 107
Sunny Sussex
Wil, thanks for the offer - i popped down to the local tyre place and they gave me some from what i think was a motorbike tube, got some funny looks lol but was free :)
Lorry tube is preferred!
