Home > Help Needed / General Tech Chat > ms
turboestate
Member #: 362
durham area
hi just built up a stim for the ms and when checking its operation i can only get the rpm up to 185 everything else works fine has anyone had this prob before ? using a v3 board wired for ford edis any help is great
love that straight cut scream!!!
______
/___|_____
_ (@)___(@)
Ben H
Member #: 184
Melton Mowbray, Pie Country
Make sure that the software in the MS is configured correctly. If it is not set for EDIS or the number of cylinders is wrong you will get odd readings.
Other than that it must be a problem with your 555timer circuit. Double check you have the correct capacitors and resistors installed.
http://www.twin-turbo.co.uk
Mike
Member #: 107
Sunny Sussex
y and its quite easy to get the posts mixed up too. Btw are you running the stim off 9v or 12v? If its 12v you'll need to change R9 for a different Ohm rating or it'll go pop.
