Home > Help Needed / General Tech Chat > ECU
Metro Turbo
Member #: 437
Sunny Blackpool
If I unplug the ECU, what will be the resulting effects?
Cheers, Tim
89' Metro Turbo
157 BHP , 170 lb ft @ 15psi .... So far....
Mikeanics Rolling Road
WINNER OF RETRO CARS SHOW BEST 80's MODIFIED CAR
Nick
Member #: 154
Midlands
it wont work *tongue*
Dangerous
Member #: 417
Block the pipe that goes to it up aswell,then you will run 3psi all day..Put a switch on the bleed solinoid(the thing next to the fuel reg)and you will have switchable 3 or 7 psi
Metro Turbo
Member #: 437
Sunny Blackpool
Ok thanks, but what sort of switch do you mean? An electrical on/off type patched into the live feed of the solinoid and site it inside the car?
Edited by Metro Turbo on 13th Feb, 2006.
89' Metro Turbo
jimmy
Member #: 829
essex
Or you can fit a bleed valve and bin the turbo ecu
1293 Turbo mini
Dangerous
Member #: 417
yep just remove the plug that is on it,then one side is earth the other positive via a switch in car.Best if you get a supply for the switch from the ignition switch/fusebox..........so you cant leave it turned on
Metro Turbo
Member #: 437
Sunny Blackpool
Cheers for the info...
For now I will just block off the ECU so that i'm on 3psi whilst running the engine in.
Then once I've got some more miles on it, I'll install a bleed valve or install the solenoid switch.
Thanks alot, very helpful...*happy*
89' Metro Turbo
