Home > Help Needed / General Tech Chat > Oil leak!
tamnorris
Member #: 590
Solihull
^^ on a mini? really!?
Yeh but this ones quite bad.
My mini has now started to loose oil at an alarming rate.
It seems to be coming from the rear of the engine somewhere but i can't locate it.
I have oil according to the dipstick. I have a decent pressure.
My oil feed feed pipe has chaffed but its not leaking (ian at avonbar is sending me a new one!!. i do have a steady drip from the gearbox but this does not appear to be in the right place for the leak.
It also appears to be worse when i'm moving leaving a large puddle every 15 or so yards.(depending on speed etc etc)
Any ideas or am i being thick!?
Matt
It was like that when i got there!
block to gearbox join?
tamnorris
Member #: 590
Solihull
Worth an inspection!!
Thanks for the two quick replies.
Matt
my money on one or both of these
the remote gear link oil seal or....
the diff out put oil seals these can all be changed with the engine in.
the diff output oil seal i bet its the one on the drivers side as this goes hard because of the heat of the exaust clamp where its bolted to the side of the seal
tamnorris
Member #: 590
Solihull
I'll let you know tomorrow when i can get it on some ramps for a better inspection!
Thanks guys.
Nick
Member #: 154
Midlands
could also be the turbo oil drain... *indifferent*
jimmy
Member #: 829
essex
what about the timing chain cover or speedo drive running down the back of the gearbox
Edited by jimmy on 13th Feb, 2006.
1293 Turbo mini
tamnorris
Member #: 590
Solihull
Thanks guys, its the timing chain cover and that half-moon seal thingy (technical speak).
Should have that sorted soon.
i once ran what could only be described as a total loss oil drain system, theat makes a hell of a mess
from the back of the engine
turbo oil feed
turbo oil drain
gearbox gaskets
diff gaskets
diff seals
rod change oil seal
tamnorris
Member #: 590
Solihull
Lol sounds a bit like mine,
Minus the diff seal leak *surprised*)
i had a 'moment' where i started the engine with no oil pressure sender in the block, it pissed all over the back of my mate LOL
LOL!!!!!
