Home > Help Needed / General Tech Chat > Relocating fuel tank in an estate
Neil8p
Member #: 65
South Yorkshire
I'm after ideas for moving the fuel tank in an estate. Only thoughts I've had so far are have something made that will fit in the spare wheel well and fit a raised boot floor over the top.
Would like to stick with the 6 gallons capacity as well if possible.
Any other suggestions would be appreciated
Neil
why would you want to move it from the std position though??
Mike
Member #: 107
Sunny Sussex
it move it to over the rear wheels thats the only advantage i can think of, i thought about moving mine to one in the spare wheel well but if i remember rightly it would of been a smaller tank too.
Neil8p
Member #: 65
South Yorkshire
A few reasons - move the weight over the rear wheels as Mike said would be the main one.
Just thought I'd ask if anyone had thought about it
Mike
Member #: 107
Sunny Sussex
y thought about it but was cost prohibitive (sp?) for me.
Anyway, where would you put the spare wheel? :)
Neil8p
Member #: 65
South Yorkshire
The spare never fitted under the boot floor anyway so it just used to rattle around in the boot
I'll get some card, tape and scissors and have a play - Blue Peter style :)
Mike
Member #: 107
Sunny Sussex
could you remove the spare wheel well and fit a tank in the middle of the rear subframe? Just a thought
That would probably work quite well, you could cut the rear floor out, mount the tank underneath in the middle of the subframe, and then have a flat floor inside the back of the car.
Would be OK for your green estate neil.....but not the woody !!!!!
Mike
Member #: 107
Sunny Sussex
what sort of capacity tank would that give u then?
Neil8p
Member #: 65
South Yorkshire
Thanks, I would be interested to know dimensions but don't go to a lot of trouble if it's not handy. I've got an idea of a shape in my head, and if it will fit I was thinking of approaching Owens Fabrication for a quote.
This has also got me thinking about the tank in my brothers Morris minor saloon. I think the tank would be too big, but the way it's mounted has given me some ideas.
Dangerous
Member #: 417
Here's one being made just flick forward and back a bit
http://www.xs4all.nl/%7Ethimo/dagboek/226.html
