Home > Help Needed / General Tech Chat > Side mount rad good enough?
Mike
Member #: 107
Sunny Sussex
doing the measuring up and to get the metro rad, an intercooler and an oil cooler up front is almost impossible. I'm going to make a visit to the local scrappy to have a poke about in some cars for smaller rads but i'm just wondering if i'm wasting my time with front mount.
Is a good side mount ok up to the job? Its a clubman flip front so theres no inner wing and i'm concerned that it wont be as efficient so shall i stick with a front mounted?
Ben H
Member #: 184
Melton Mowbray, Pie Country
This has been covered plenty of times I think. The side mount does a fine job. The 2 core one from minispares is the one to go for IMO.
If you want a small rad to fit up front take a look at the fiat cinquiento they are a supprisingly good bit of kit and small.
http://search.ebay.co.uk/search/search.dll...ator&category0=
http://www.twin-turbo.co.uk
jimmy
Member #: 829
essex
Mini 2 core rad are good
http://www.ebay.co.uk/MINI-2-CORE-UPRATED-...ATOR-RACE-RALLY
Edited by jimmy on 13th Feb, 2006.
1293 Turbo mini
Mike
Member #: 107
Sunny Sussex
will a side mount still be as effective without a inner wing?
As long as you keep the fan and the cowling it should be fine. We run ours like this and have no problems.
I ran it on the road (non turbo) for years with no problems either. If you are worried, you could always make an alloy inner wing.
Wil
i run a side mount minispares 2 core, no mechanical fan and a rover 214 electric fan
no inner wings, seems to be doing ok
Mike
Member #: 107
Sunny Sussex
cool, think i'll scrap the front mount plan for now then, also means i can ditch the expansion tank too.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
hmmm a bigger side mounted rad might be worth looking at...
without inner wings theres a fair bit more room there!
alex
AlexF
