Home > Technical Chat > Mains
why are the turbo and non turbo mains different? eg side or centre locating tab ect
The turbo "type" mains do not have the oil groove in the lower shell. This gives a bigger bearing area, and can support more load.
However, all of the later 1275 engines adopted this type of main bearing, I think from 1986 (?) onwards.
And to be even more technical, none of the big names when it comes to A-series engine building likes the new type.
The mains should be crossdrilled for this which they are NOT.
Read this:
http://www.minimania.com/web/threadid/6849...0/msgthread.cfm
http://www.minimania.com/web/threadid/6469...6/msgthread.cfm
Edited by Vegard on 16th Feb, 2006.
any late ish A plus block will have solid shells in thre caps on the mains,and the centre groove for the tang,even if you have an early block [even A series] still use the later shells and file thr groove in the right place,
carl
I don't neccesarilly agree with that to be honest... just look at the evidence - If it was a problem, we'd be spinning mains left right and centre. I can't EVER remember anyone doing that for as long as this site has been going...
And putting my engineer hat one, something with a hole in it is generally weaker than something without a hole in it. I can't see that i'll ever cross-drill a crank until the time that i start turning past 7500 rpm - which will be never as long as i'm sticking to a turbo...
Edited by turbodave16v on 16th Feb, 2006.
I agree with you Dave, that's why I wrote "should". I find it interesting that we don't have more spun mains. All other manufacturers using these kind of bearings have cross drilled mains. (Germany)
Also, some old S cranks and ALL cranks from MED have got cross drilled mains as far as I know.
ah! Gotcha with the 'should' bit..... *wink*
Yes, the should bit in that post was really easy to miss..NOT!
Spridget
Member #: 629
Colchester
I found this article on turbo mains/through drilled main journals. Worth a read
http://new.minimania.com/nmm/Turbo_Bearings.htm
No, that article is NOT worth a read as it is W R O N G !!!!!!
No Metro crank ever had through drilled mains.
The only ones were the MK2 S-crankshaft.
Someone should contact Minimania about that rubbish article.
i'm still trying to work out why you'd need crossdrilled mains,
carl
to save weight?
in that case i'm going to put a 22mm hole in them,
tom will work out how much i save,lol.
carl
Making a few assumptions, you'd save 0.489kg.
I think crank life would be somewhat compromised though.
*laughing**laughing**happy**laughing**happy**happy**laughing**laughing*
Oh, and before anyone else calls me it, BAC.......
On 10/03/2006 21:03:09 mini1071s said:
carl
You're probably joking, (if you don't need them NONE of us peasant do!), but my understanding is that it stops all the oil centrifuging out of the crank at very high rpm. Like 9000rpm lol.
Maybe, not sure now!
we are talking MAINS here .
hello wakey wakey .lol
carl
Yep, not a huge amount of centripetal force at a 1" radius from the crank centreline......
On 10/03/2006 21:47:26 mini1071s said:
Well my excuse is I've just come back after a week working 19hour a day on a survey ship in the atlantic and I got so drunk last night I was too pissed to drive back from the docks tonight, had to get the GF to drive me back, I can't remember what I did last night and I'm worried cos the russian captian was looking at me funny and kept giving me black vodka. Come to think of it, my arse is sore, is it the diet of curry or...oh f@ck!
I think I need a beer.
old sea dog,
old sea dog, aha ha ha ha !!!!!!!1
