Home > Help Needed / General Tech Chat > heater?????
Slobo
Member #: 883
Shillington, Pennsylvania, USA
I just bought a turbocharged MIni. When I got it the heater was just hanging down on the clutch pedal. When I tried to fix it, the box in the firewall for the turbocharger keeps the heater too far from the brackets to hang the back of the heater right. How do you get around this. I need room for my foot on the clutch....
"Stick your foot in it"
nogin
Member #: 487
westbury, wiltshire
i had to swap the heater matrix inlet and outlets to the other side of the heater and make some brakets to fit the heater to the firewall and bottom rail
"Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
i also make things
i love coming home to chrome
jimmy
Member #: 829
essex
you need to mod the brackets at the rear of the heater and redrill the front holes so went you refit it you can move it to the left for more room on the clutch side
1293 Turbo mini
Carl
Member #: 95
liverpool-on-sea
its just a simple job of making a ouple of little brackets and posistion it so your happy with it*smiley*
Slobo
Member #: 883
I'll try to figure out some new brackets. Can you believe someone would drive this thing around for years with the heater literally one inch from the clutch?
Yes i can*laughing**laughing*
SumpNut
Member #: 28
I never had much room to use the clutch even after remounting - unless you ditch the origional front mounting point?
t3gav
Member #: 229
Gavin@minispares.com
kent
i remember a similar post to this a few years ago and my heater is still held in with some wood screws and some zip ties as are a few others i believe lol
Wood screws!?
Next you will be using a plastering trowel to do bodywork! Or gardening implements!
