Home > Help Needed / General Tech Chat > Head Gasket, what to do humm?
So the head gasket on my 998 road mini keeps blowing. Firts time between 2 and 3, then between 3 and 4, and just now I take of the head and it;'s gone between 1 and 2.
all the surfaces look good but the gaskets (Payen copper type) are only lasting around 1200 miles.
I'm probably goint to slap it back on with another gasket, making sure it's super clean.
Any other thoughts/advice?
Wil
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
flat edge and feeler guages....
or
sheet of glass, engineers blue and grinding paste!
Alex
AlexF
flat edge and feeler gauges show it's nice and flat.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
then have a play with the glass...
If its mecury floated glass its very very flat... a bit of paste and some blue will soon show up any funny spots.
I haven't just it for a while, but it worked a treat on a lawnmower head a repair shop near me couldnt sort lol
Alex
AlexF
I'd change the studs as a first measure - unless you're convinced they haven't been 'abused' (overtightened) at any point...
Check the accuraccy / repeatability of your torque wrench?
Try a completely different head gasket?
Chamfer the head bolt holes in the block?
How is it blowing Wil? You can usually gather some info from the area it has been leaking. Are you sure your radiator and water pump are up to scratch?
Well it's all back together now.
The engine was completly unabused when I got it I was the first to remove the head, so studs are fine I reckon.
It's blowing between the fire rings, but never the same pair and the others always look fine.
We'll see how it goes.
nutter driver
Member #: 47
Not very sunny swanage
just a thought, you havent been using the same batch of gaskets or anything, ie bought a dozen at a show and keep using them? long shot, but hey....
It's not detting is it? Have you tried retarding your map a few degrees??
I was just thinking that as I drove to the kebab shop in it. i get the laptop out tomorrow and retard the map a couple of degrees.
Might be worth doing a plug chop on it if you can after a decent run.
andeh
Member #: 97
Near Daventry, midlands
if it happens again, try using a different torque wrench. A friend had the same problem, his wrench was over-torquing the head and had actually stretched some studs.
Well it got me to work and I just checked my torque wrench aginst the lab one and its about 1Nm out. But as I always put it to 70 ratther than 68 it's about spot on, it was consistant too.
turbo hogster
Member #: 178
stowmaket suffolk
i had that problem with them sort of gaskets i then swapped to the grey type of payern gasket and never had a problem after just a thought wil.
Skinns46
Member #: 165
Cambridge
Quite a lot of the time we find on the 998's that the problem is the head. If you can 'lick' a bit off i think that'll sort you.
http://photobucket.com/albums/y139/Skinns46/
Pete, how did you find that out??
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
how have you mapped the engine?
Alex
AlexF
The mixture aint too weak is it?
Paul
Alex
On the rolling road, same goes for fuelling.
