| Home > Help Needed / General Tech Chat > Diff Pre-load | |||||||
![]() 19 Posts Member #: 749 Member T'other side of Manchester |
16th Feb, 2006 at 08:54:53pm
I am in the process of putting the diff back in the gearbox casing... however is there a step by step off how to do this as I dont quite understand the Haynes manual...
16th Feb, 2006 at 09:02:44pm
The main diff casing needs to be in place but loose to allow the diff bearings to move. Then you fit the side covers as per the manual.
16th Feb, 2006 at 09:08:57pm
16th Feb, 2006 at 09:19:54pm
You bias the entire assembly one way, then nup the covers up to measure the gap, this allows you to select the correct shims, then you bolt it all up, the shims mean that the diff has a compressive force across it, so it cannot move.
17th Feb, 2006 at 09:02:44am
you need 1 thou pre load if iu remeber right.
