Home > 998cc > Which Actuator?
garethlloyd
Member #: 616
Birmingham
Ok, picked up my R5 T2 for the thou last week.
I'm just wondering which actuator would be best.
I plan on running 8psi.
Should I be looking for a standard r5 actuator or do I need something else?
Gaz.
Kean
Member #: 341
aka T2clubby
South Staffs
If you only want to run 8psi, I would stick with a standard one, no idea what they are set at though... you may need a bleed valve
Oh and you will need to remount it on the other side of the turbo to make it fit
i got a billet forge one as its quite a bit smaller. makes it easier to locate etc plus its adjustable for different boost ratings.
garethlloyd
Member #: 616
Birmingham
OK cheers guys.
