| Home > Technical Chat > Twin plate clutch... | |||||||
169 Posts Member #: 409 Advanced Member Bristol |
18th Feb, 2006 at 06:46:05pm
Hannibal: There are two ways we can do this: the easy way and the hard way. In a few minutes my friends and I are going to come down on you like your worst nightmare. You're gonna wish the Earth had opened up and swallowed you whole.
18th Feb, 2006 at 07:05:40pm
no it dosn't give twice the grip , it gives you twice the wear ,its the same preasure clamping . there may however be a little more grip available by virtue of less heat build up in each plate ,then again may not ..
18th Feb, 2006 at 07:21:19pm
Mmm, see what your saying. I must admit that I can see little advantage myself!
18th Feb, 2006 at 07:22:33pm
http://www.minimania.com/web/threadid/7434...1/msgthread.cfm
18th Feb, 2006 at 07:30:23pm
'cor blimmy your a grumpy git TD! Hannibal: There are two ways we can do this: the easy way and the hard way. In a few minutes my friends and I are going to come down on you like your worst nightmare. You're gonna wish the Earth had opened up and swallowed you whole.
612 Posts Member #: 414 Post Whore Dalbeattie Scotland |
18th Feb, 2006 at 08:35:20pm
Isnt there more friction area which would mean less slip as in a motorcycle setup there are no strong springs on most 160bhp bike engines but loads of plates usualy 8 or 9 ish.
18th Feb, 2006 at 11:26:08pm
Thats what I was thinking, esp' as most multi plate 'bike clutch's reside in oil!
18th Feb, 2006 at 11:41:02pm
two plates will handle more torque.... in theory!
AlexF |
18th Feb, 2006 at 11:54:17pm
twice the surface area innit! Hannibal: There are two ways we can do this: the easy way and the hard way. In a few minutes my friends and I are going to come down on you like your worst nightmare. You're gonna wish the Earth had opened up and swallowed you whole.
19th Feb, 2006 at 12:39:47am
They'll hold the torque, but once both plate have worn just 1mm (0.5mm per friction surface) you'd be better off with a stock verto clutch...
19th Feb, 2006 at 10:30:29am
would it not be worth looking at untill someone sorts the verto setup?
AlexF |
21st Feb, 2006 at 01:19:14pm
I was thinking along the lines of twice as much surface area mus be able to hold twice as much torque (or the same torque with half the clamping force).
21st Feb, 2006 at 01:46:35pm
It's nothing to do with area at all - friction is dimensionless (has no units). Hence you could take an organic plate and chop 90% of the material away - and it'll still hold the same torque.
21st Feb, 2006 at 03:35:32pm
The formula to calculate the maximum torque transmitted is:
AlexF |
21st Feb, 2006 at 10:25:31pm
A f1 car uses a cluth approx the same as a 500cc suzuki quad bike...fact
22nd Feb, 2006 at 12:29:31am
yeah but dont they also have hydraulic computer controlled actuation, and so can be stupidly heavily sprung? turbo 16v k-series 11.9@118.9 :)
