Home > Help Needed / General Tech Chat > Crank sensor clearance
Can anyone tell me the preferred clearance between the end of the Ford EDIS sensor and the toothed wheel?
less than 1mm gap is where mine are mounted
Thanks Wil_h
Answered in less than two minutes - not long enough to drink me cup of tea before I get back to the barn!
Don't mount closer than 0.5mm however... They can ceate a high enough spike to kill fragile ECU's if mounted too close *wink*
I've just modified the bracket to give about 1.5mm - that looks close enough to me. The bracket is not that stiff and I'm a bit worried about vibration.
Presumably there is a maximum at which it will not work.
Time for another cup of tea while the paint dries and I can try it again.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
0.030 to 0.060 inch gap
or 0.762 to 1.5mm gap
Alex
AlexF
Thanks everyone.
I'll leave it at 1.5mm.
If it does not work I'll let you know.
