| Home > Help Needed / General Tech Chat > Piston Removal Problem | |||||||
19th Feb, 2006 at 11:32:59pm
Hi guys, yesterday i was taking the pistons out of my block. I was undoing the bottoms of the rods and pulling the pistons out through the top as described in the haynes.
125 Posts Member #: 751 Advanced Member Aberdeen |
20th Feb, 2006 at 12:30:39am
Are you going to be using the same pistons and rings when you rebuild? If not can you remove the piston ring that has opened up then the piston should beable to push back up the bore.
20th Feb, 2006 at 12:53:00am
2 steady hands and some sharp screwdrivers should see the oil scrapers pushed back into the pistons and the piston back into the bore. will be fidly as hell but do-able. turbo 16v k-series 11.9@118.9 :)
20th Feb, 2006 at 02:21:06am
As Dan said - if it's new rings, then just break the offending one off, and push upwards... On 17th Nov, 2014 Tom Fenton said:
20th Feb, 2006 at 09:52:02pm
I did this once too
