Home > Help Needed / General Tech Chat > any maths gurus out there?
giallofly
Member #: 164
The Stig..
Newport Pagnell
So if you have a 40mm tube inside diameter how many square mm will the hole be?
Then...
if you have a 48mm I/D tube how may square mm would the hole be?
Them as a percentage how much bigger would the bigger hole be over the smaller hole??
God i wish i had pay some attention!!!
JF.
Leonard
Member #: 806
Cirencester, Gloucestershire
40mm = 1256mm squared
48 = 1809mm squared
44% increase
(I hope thats right)
colas
Member #: 102
Pennsylvania USA
180.96mm I got it to.
SumpNut
Member #: 28
48mm ID has an area of 1809 Square mm
40mm ID has an area of 1256 square mm
I make 48mm ID to have a 30odd% larger internal area
Edited by SumpNut on 20th Feb, 2006.
Ben H
Member #: 184
Melton Mowbray, Pie Country
Pi*r^2 (r = radius)
Pi * 20 * 20 = 1256mm^2
and
Pi * 24 * 24 = 1809mm^2
Percentage is a bit odd though I guess the easiest way is:
If you take the bigger to be 100% then
1256/1809 * 100 = 69%
so 40mm tube is 31% smaller area.
Ben
http://www.twin-turbo.co.uk
Leonard
Member #: 806
bugger we all got a different percentage
1256 *1.44 (44% extra) gives 1809
t3gav
Member #: 229
Gavin@minispares.com
kent
its 44% because: eg a 1.5m long pole is 50% longer than a 1.0m pole 1.5/1.0 = 1.5 whereas 1.0/1.5 = 0.67 which is wrong
Well, you will get different percentages because 1% of each area is different. That means the smallest is 31% smaller compared to the big one, but the largest is 44% compared to the small one :)
Easy!
t3gav
Member #: 229
kent
yep just giving an example everyone can understand, is easy if you think of it with those easy numbers
giallofly
Member #: 164
The Stig..
Newport Pagnell
so the larger pipe is 44% bigger?
It is the measurements of a standard MG Metro turbo down pipe over a Maniflow item that most of us use on T3's.
Thanks all.
JF
Dangerous
Member #: 417
Hi jack
If I have a std size 1.750" crank pin dia,and put a rod and piston in with a -.020 shell on (like some wazzuk did) just the top part of the rod.......
How much higher would the piston be
I can't work it out
t3gav
Member #: 229
kent
yep thats right jon the bigger one is 44% larger i assume this is the maniflow one?
Still Pissing in the wind if your elbow hasn't been opened out!
giallofly
Member #: 164
The Stig..
Newport Pagnell
Dave please!
Edited by giallofly on 20th Feb, 2006.
hee hee!!!
Was this already done on your 'front running' racer - or is this even more then? I'm guessing the latter? *smiley*
