Home > Introduce Yourself > New member - about to embark on Turbo conversion
ben.harris
Member #: 907
Cambridge, UK
Just though I should introduce myself, before I start asking all sorts of questions on here!
I've recently bought myself a Metro Turbo on eBay which has quite a few engine mods already, and have removed the engine with the intention of putting it into my Mini which has been off the road for the last 3 years awaiting restoration.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...item=4606979338
Ben.
Welcome, Ben :)
colas
Member #: 102
Pennsylvania USA
You're at the right place. There are a lot of knowlegable people on here.
turboestate
Member #: 362
durham area
welcome you wont be disapointed *happy*
love that straight cut scream!!!
______
/___|_____
_ (@)___(@)
Hello Fella
Welcome Ben
Add your location in the world to your profile, there may be members on here local to you.
T3Tone
Member #: 252
Sunny suffolk
Hello and welcome
-MINI CLUBMAN 1380 TURBO-
Welcome!
First thing I'd do after getting that metro is whip the head off and check that it is what it says it is *wink*
ben.harris
Member #: 907
Cambridge, UK
That's what I intend to be doing at the weekend. We (myself and a friend) took the engine out of the Metro last weekend (dropped the subframe and lifted the body over). I managed to get it running before we took it out which is a promising sign, and there was good compression on all cylinders (about 175psi - is this too high for a turbo?).
I assume it'll be fairly obvious if the head's been modified as he says it has, but is there anything in particular I should look for?
Ben
well, the 1.5 rockers would be VERY easy to spot just by lifting the oil cap...
ben.harris
Member #: 907
Cambridge, UK
It's been a while since I looked at my mini engine, and it's not here at the moment for me to compare it with. I've just been outside (it's very dark and cold out there!) and taken the rocker cover off to have a peek. The rockers have got Avonbar written on them, so that's convincing enough for me that they're not standard. :)
Couple of pictures here:
http://img.photobucket.com/albums/v11/ben....ni/DSC00164.jpg
http://img.photobucket.com/albums/v11/ben....ni/DSC00165.jpg
Edited by ben.harris on 22nd Feb, 2006.
Indeed!
Despite the grubby exterior - it clearly looks very clean inside. Head has certainly had something done to it looking at the machining.
yes it looks like it sports niamonic Ex valves as well
its all pointing to a turbo engine
at a guess! its an early avonbar engine some ten years ago
ben.harris
Member #: 907
Cambridge, UK
The engine was supposedly built by a guy called "Mike Jennings", who (according to the guy I bought it from) has an article in one of David Vizard's books. I would also guess it was built just under 10 years ago - The previous owner has had the car for the since 1997, and it's been off the road for the last 4 years (It's now in pieces on my parent's drive! *evil*).
I thought it looked like quite a lot of engine for not a lot money (considering what it'd had done to it), and was well worth bidding on! I know that turbo engines are getting a bit harder to find than they used to be (well, for a reasonable price, anyway).
wylyeguy
Member #: 704
salisbury
Hi Ben,
Like you im embarking on fitting a turbo lump to a mini and found this forum to be excellent.good luck.Dave.
wylyeguy
Member #: 704
salisbury
On 21/02/2006 19:47:57 T3Tone said:
Hello and welcome
Just seen your project am very impressed you must be chuffed to bits,im in the throes of doing the same as you but mine is an old mayfair.Dave.
